MadProfessor8138
I'm drawing out the wiring diagram for my Rotax 670,Wapsiaero EIS and rotor tach. by using the available Rotax 582 information as a guideline.
Surprisingly,there's not much straightforward information about the wiring available,even the official Rotax install guide is pretty much useless.
I have questions :
1. How should grounds be ran ?
A. Engine to airframe and then battery to airframe ?
B. Engine to battery and battery to airframe ?
2. Does the starter on the E-box need a ground wire to the airframe or battery....or will the ground through the engine case attachment be sufficient ?
Kevin
I have questions :
Kevin
