I am having problems getting aircraft grade plywood in Paraguay. I could get 0.6mm veneer of good quality. Since I cant do the heat press that phenolic resin requires, wouldn't it be possible to join the veneers with resourcinol, since that is the glue I plan on using for the aircraft anyway?
That way I could use a vacum press to make my own plywood...
