I know most of the properties. I have covered planes and know enough about composites that it would be a total mess if covering was done traditionally with carbon. All aircraft use to be sewn. Glue use to not be good enough.
Glueing it. Would you pick a classic fabric contact type or would you epoxy? Traditional stuff oozing through would probably be more successful. Epoxy would have to be clamped. You could get a couple of panels done where you can access the whole tube. You would probably have to do one tube and wait, and work your way around as each cures. Spanning between like the belly would cause new issues. No way to clamp. Super glue corners?
Just the unraveling when fingering the raw carbon is a mess. Rows of the weave will unravel. I guess one could treat it somehow.
After it’s attached you have to fill the weave with epoxy. I imagine one coat to imbed. And at least another to level it. Do you choose thin and very fast or slow and thick?
Endless questions to answer just to figure out the process. Then you can have the conundrum of if it looks good.
