Skippydiesel
- Oct 18, 2020
- 291
Speculating:
If you have a fixed pitch prop, a MAP gauge is of very limited use.
Ground Adjustable Fixed pitch props are usually set on engine rpm.
If you don't have a factory advised initial pitch setting , tie the aircraft down & set pitch for Minimum Continuous rpm @ WOT
This should deliver acceptable TO & Climb performance
Go fly - Note TO, Climb & Cruise performance @ WOT
Land
Make pitch adjustments to improve to your performance preferences
Land
