jedi
The Lottie is an ongoing USA FAR103 Advanced Ultralight design project.
In response to questions that arose from other sources within the HBA community I am skipping over the history and overall design goals for the present and posting current development and design of components that others may find of interest so that we may collaborate on design proposals.
The following is a 1/8 scale planform paper airplane that represents the rear wing aerodynamic surface of a tandem biplane. It is a simplified plan of a (foldable in full scale) delta wing composed of common household products. The plan can be expanded and further developed by other builders to suit their interests. I am available to share my future plans and will provide additional plans if anyone is willing to build additional models or full scale components.
With reference to the attached drawing transfer the right semispan drawing to a standard 8.5 X 11 sheet of writing paper. All dimensions are in inches. Cut and fold as indicated. Additional folds may be added to keep more material towards the swept leading edge (top of the drawing).
Repeat the mirror image for the left semispan or use an inverted symmetrical right wing on the left.
Combine (household mending tape works well) the right and left wing sections at the centerline. An airtight seal is not necessary.
Add material as necessary for a keel, leading edge and wing spar and to position the CG 3.5 inches or less from the leading edge. Light creases may be added to simulate the radial rib lines an a slight reflex may be added with a slight bend on a line connecting the keel and wing tip trailing edge.
I used popsicle sticks and soda straws for additional structure. Photos to follow.
