Regulations - Aircraft Certification
Will Aldridge
Oct 30, 2009
997
Northern Utah
The purpose of this thread is to provide quick access to the regulations regarding aircraft certification. In the U.S. FAR 23 has a considerable amount of data regarding the loads and limitations that aircraft should be designed around. For designers this is an invaluable resource. If you are thinking about designing your own plane I can guarantee you that the more experienced members of this forum will sooner or later tell you to look up FAR 23.
In keeping with the international nature of this forum I will also list links to other countries regs as they are made available to me. If you post a link and don't see this top post modified to include your link please pm me. I do have a life so it might take a day or 2. Once links have been added posts will be deleted to keep things uncluttered.
Thanks to Jake for making this a sticky and for giving us this great site.
United States: FAA Regs
All FAR's
Regulatory and Guidance Library
Experimental Amateur Built
FAR 23 Certification Specifications
Ultralight Regs
Part 103
AC103-7 Determining if part 103 compliant
Miscellaneous
AC 90-89A - "Amateur-Built Aircraft and Ultralight Flight Testing Handbook"
Road regulations
Federal Motor Vehicle Safety Standards and Regulations
Vehicle Standards and Regulations | Cars and Light Trucks | US EPA
http://www.dieselnet.com/standards/us/ld_ca.php#leviii
Europe
EASA- Certification Specifications
EASA-General Aviation FAQ
  • CS-23, VSo below 61 kts, IFR possible, max 19 people on board
  • CS-22, VS0 80 km/h without and 90 km/h with water ballast, 750 kg MTOW, 850 for double seaters and engine*
  • CS-VLA, VSo below 45 kts, VFR only, max 2 people on board, MTOW 750 kg, normal category only *
  • CS-LSA, copy of the FAR-LSA regulations. Read more
  • MLA, regulated per country, VSo below 35 kts, 450 kg MTOW with 2 pob, 300 kg when single seat. 25 kg extra MTOW with a BRS.
*Proposed changes are a raise of the MTOW of gliders to 900 kg and the approval of CS-VLA for night-VFR and a raise of the latter to a MTOW of 890 kg. Relaxation in certifying/allowing aircraft below 1200 KG is expected (ELA1 process)
Czech Republic
Czech ultralight airplane requirements UL2-1: http://www.laacr.cz/formular_downloa...FORMULAR_ID=12 (non English site)
Germany
German ultralight a/c requirements LTF-UL: http://www.pilots24.com/pilots24/dow...F-UL202003.pdf (non English site)
United Kingdom
http://www.caa.co.uk/docs/33/CAP659.PDF
HAB thread on topic: Where to start?
Microlight a/c (450 kg) requirements BCAR-S:
http://www.caa.co.uk/docs/33/CAP482.PDF
Some additional info: BCAR-S interpretation: http://www.bmaa.org/files/til016_1_i..._of_bcar_s.pdf
BCAR-S and LTF-UL bridging: http://www.bmaa.org/files/til037_2_s..._vs_ltf-ul.pdf
