I feel like I should know better but here it goes- the following is the list of parts that I either currently have or in the process of acquiring to build up the 13B-T for my Long-EZ.
Engine-
13B Series 5 semi-P-Port side housings, studded, P-Port tubes are steel and the intake side O-ringed to prevent coolant leaking or being pressurized.
13B Series 6 Ported rotor housings
Renesis rotors, cut for "RX7" 13B apex seals, balanced
Renesis E-shaft, counterweight, and front stack, balanced
Goopy Performance Apex seals
Cryo treated front and rear stationary gears
Cryo treated corner and side seals
Fabricated intake manifold
Billet throttle body
Intercooler
T4 turbocharger
Fabricated 321 Stainless exhaust manifold
Manual waste gate
AEM Infinity ECU
AEM CD7 display
AEM wideband controller
redundant 320lph fuel pumps
Aeromotive AFPR
IGN-A1 ignition coils (coil per plug)
Formula Car (for lack of a better name) radiator cores from Ron Davis
Twin oil coolers
This is the "bare bones" of the system. I will go into more detail when I can.
Engine-
Intercooler
T4 turbocharger
Manual waste gate
AEM Infinity ECU
AEM CD7 display
Aeromotive AFPR
Twin oil coolers
