Attached is a fairly famous spread sheet with my numbers, and a FEA report at the target location. I used pin constraints of the same diameter as my target design conversion. I only pretend to know what I am doing so any help the more experienced can give will be appreciated. I have many questions about the proper FEA inputs and about the proper spread sheet input. I promise not to sue you if I die in an aircraft accident.
