I have read about and seen a video of a larger rudder for the II L and was wondering if anyone had drawings or other information about it. I am preparing to recover the fuselage and it seems like the ideal time to build a new rudder.
Upgrade NowI made my vertical fin and rudder bigger while repairing accident damage but the airplane hasn't flown yet. The height increase is seven inches over the standard 2LS tail, based on advice I got from Tim Kline, who was the first to do this as far as I know. I hope to find out this spring whether the taller fin achieves what I wanted.
Ed
2LS
I did the same on my SII. The result is that when you depress a rudder pedal to the floor, the ball/slip indicator returns to within 5 degrees of centered. Also if you perform 90 degree reversing steep turns, without the larger rudder the aircraft is divergent. With the larger rudder it turns normally. (Divegent means that when you use the rudder to correct for yaw in the turn, the aircraft attempts to tumble. )I made my vertical fin and rudder bigger while repairing accident damage but the airplane hasn't flown yet. The height increase is seven inches over the standard 2LS tail, based on advice I got from Tim Kline, who was the first to do this as far as I know. I hope to find out this spring whether the taller fin achieves what I wanted.
Ed
2LS
I put 30+ hours on it before selling. My turtledeck was raised 3 inches. The rudder authority was good and as expected with no fishtailing at cruise.
I've added at least another 30 hrs and have found it very stable; slips well too.I put 30+ hours on it before selling. My turtledeck was raised 3 inches. The rudder authority was good and as expected with no fishtailing at cruise.
Any update on larger rudder design?I made my vertical fin and rudder bigger while repairing accident damage but the airplane hasn't flown yet. The height increase is seven inches over the standard 2LS tail, based on advice I got from Tim Kline, who was the first to do this as far as I know. I hope to find out this spring whether the taller fin achieves what I wanted.
Ed
2LS
