Armilite
So by their Info, a 277UL with the right Prop should work also. They only show a 60" & 63" Prop. A Rotax 277UL (26hp@6250rpm) with a 2.58 Redrive at 77F using a 63" x 19 Pitched for 2,322.5 rpm = 227.83 lbs Static Thrust and needs 25.474 hp!
A Hirth F-33 (28hp@6500rpm) with a 2.5 Redrive at 77F using a 60" x 20 Pitched for 2,500 rpm = 217.18 lbs Static Thrust and needs 27.514 hp!
Just about any of these GX270+ Honda/Clones could also be used if upgraded to make 25hp+.
Prop Static Thrust Calc:
http://godolloairport.hu/calc/strc_eng/index.htm
Hi Rich.
So with what Engine is it 235lbs?
==> Hirth F-33(28hp).
What 50hp Engine does it make Part 103 254lbs?
Hirth F-23(50hp), manual start, reduction drive, no options/upgrades. It will meet the weight limit of 278 lbs with the F23(50hp), but it will zip right past the 63 MPH.
What is the Smallest HP Engine you have seen used?
==> Hirth F33(28hp)
Here is some additional info regarding weight:
If you use the F33 engine, the completed aircraft is 10-12 pounds under 254 without a parachute. With a chute, it is approximately 17 pounds under the 278. In either configuration, you can add pretty much whatever options/upgrades you would like and remain under 254/278.
Using the Hirth F23(50hp), and no options/upgrades, the aircraft will come in right about 278 with a parachute. If you are not familiar with the Part 103 language, it allows you 24 pounds for a parachute system. Since the parachute system only weighs 17, you pick up that other 7 pounds which will offset the additional weight of the F23.
Having said all that, about 98% of all UL’s are either a few pounds over the 254/278 weights, and/or go faster than 63 MPH, and nobody cares. I have personally asked guys from the FAA about a dozen times “What happens if my UL is over the weight limit.” Their response every single time has been “We have more important things to worry about.” Most owners of a single-seat UL type aircraft opt to install the engine and options they desire, and they still fly it as an Ultralight even if it is a few pounds over 254/278.
Please let us know if you have any additional questions or need any additional information.
Dennis
Aerolite 103, LLC
Magnum Parachutes, LLC
U-FLY-IT Light Sport Aircraft, LLC
386-738-4444 (Hangar)
740-407-4491 (Cell / Text)
www.fly103.com
www.ballisticparachutes.com
www.uflyit.com
[email protected]
[email protected]
[email protected]
Sent: Thursday, July 25, 2019 11:28 PM
To: [email protected]
Subject: Spec's?
Hello:
IF with Hirth Engines, which Configuration.
F-33 28hp Weight: 35lbs including exhaust sys. - 40lbs W/re-drive - 45lbs W/elec. start
F-23 50hp Weight: 78lbs, including reduction unit, full exhaust, and electric start or 71lbs with recoil start reduction unit and full exhaust
Aerolite 103 Spec's.
http://www.uflyit.com/aerolite_103_specifications.htm
Hi Rich.
==> Hirth F33(28hp)
Dennis
Aerolite 103, LLC
www.fly103.com
www.uflyit.com
[email protected]
[email protected]
[email protected]
Subject: Spec's?
Hello:
