    Why become a Premium Member?
    Upgrade Now
Pros and cons of using 12 volt fuel pump to sump a hard to reach amphibian fuel tank.
Aug 16, 2021
201
Millbury, Ohio.
I've been considering what would be the easiest and safest way to sump the fuel tank in my proposed seaplane build. I don't want a port in my hull. I also don't want a syringe type system as the Icon A5 utilizes. Since I will be fabricating a custom tank I am considering adding a dedicated line to the lowest portion of the tank which would run to an additional Facet cube pump. This pump would be plumbed in such a way so as to be easily accessed by a panel, very likely to be in close proximity to the other two pumps in the fuel system. A momentary switch would be mounted nearby and a valve at the discharge end of the line. When the discharge valve is opened and the momentary switch is pressed, fuel from the tank sump will be discharged into a collection bottle for inspection. This system could also be used for emptying the tank. The added weight and expense of such a small pump is negligible, so please, if you would, limit criticism to electrical wiring concerns and anything else I may be overlooking. I've not seen this attempted anywhere else in the literature I have searched thus far.
