For winter pre-heating on the road or tie-downs without electricity nearby. Delta 2 portable battery generator with cellular switch built inside for $650.
Details below. Comes with power cord, car charger and switchbox cellular installed inside w/ sim chip.Battery pack to increase heating time to 10 hours in pics below, if interested.
Can be used with or without cellular.
Winter Pre-Heating at the tie-downs/or transient without electricity is the job for a Red Dragon and propane/hose/battery cart setup. Those are $500 plus propane and 1 hour waiting time.
The little battery packs like the Ecoflow Delta 2 are a great unit and they let you use an EZ-Pad sump heater for up to 5 hours. Then you can just recharge it in 45 mins and use it again. They cost $1000 and a long waiting time also.
I have a Delta2 with cellular switch built in for $650 and waiting time is 0, if you start it up remotely from home. There is an expandable battery pack that can increase the heating time to 10 hours if needed. Pics below.
Delta 2
Dimensions: 8x11x12
Weight: 27lb
Extra Battery Pack (if needed)
Dimensions: 9x8x7
Weight: 19lb
Delta 2
Dimensions: 8x11x12
Weight: 27lb
Dimensions: 9x8x7
Weight: 19lb
