Gaston
- Joined
- Mar 7, 2006
- Messages
- 1,111
I posted a comment in another thread ,about Man press and RPM and I wanted to explain How I see it...
I'm far from being an engine specialist,and this is only my opinion...
you take it or leave it ,it's up to you...
it's only thinking matter....
As per GPASC literature a 1835 pumps out 65 hp at 3600 MAX
60 at 3400 Cont.
2180 .................75 hp at 3600
70 hp at 3400 cont.
in order to get these numbers available at the prop for take off,your engine must be able to turn your prop at these RPM.
otherwise forget about these numbers...
Say your engine is a 1835 and your prop turns only 3000 on climb out ,your engine is not developping 60 HP ,but much less.
so if your climb rate is marginal don't be surprised...
If you have an engine that runs your prop at such a low rpm ,before blaming it on the engine ,have a look at your prop,it may be way too pitchy...
I once had a 1835 in my sonerai that was not performing very well until I discovered that the pitch was much more than what was stamped on the prop.
after reducing the pitch of this prop ,the engine began to perform very well, Static RPM was increased by about 200 rpm.
average performance was also increased considerably.
In my opinion the high Man.pressure and lower RPM,is much harder on the engine than high RPM and lower Man press.
as per a C-172 flight manual the work load of the engine (0 320) at 2000 feet Press Alt is 75% at 2500 RPM when it is
at 8000 feet PressAlt is 64% still at 2500 RPM
with a fuel burn reduced from 8.4 to 7.2 usg/hr ,fuel burn is reduced by 17%
so I think that reduced ambient air consuming was also by 17% to maintain a air/fuel ratio near 14:1
this gives a work load reduction of 15 %related to lower manifold pressure...
in our case using 25" Mp instead of 28" Mp is a reduction of 11% of the work load
this may be far from truth but it makes a certain amount of sense.
So I use low pitch prop that allow the engine to reach high rpm.and produce maximum output,and minimal fuel burn.
this is very interesting for take & climb,giving a climb rate over 1000ft/min with my 2276
and when level ,all I have to do if I want more speed is to add a little power.
VW are happy at higher rpm.in their original use HP output were measured between 4000 & 4800 rpm depending on their size...
Personally my 2276 can reach and maintain around 3350 rpm on climb out depending on actual conditions,
and I feel very comfortable using higher RPM.
Gaston
60 at 3400 Cont.
70 hp at 3400 cont.
Gaston
