skyking
Recently completed Hummel Ultracruiser from kit (450 build hours) with following add-ons: Canopy, Throttle, Cabin Heat, Spinner. 45hp Scott Casler 1/2 VW Engine - hand prop, dual ignition. Prince 54x28 Carbon FIber E-Tip Prop. One hour on Hobbs for engine run-up and initial test flight. UMA Analog Airspeed, AvMap EFIS, MGL Digital Oil Temp/Pressure/Volts, Flight Data Systems T-30 Tach , Garmin GPS 396 in panel. External Antenna with coax and control stick PTT for handheld hookup. LiFePo 16aH battery with charger for panel and secondary ignition. Seat Cushions. Black Max brakes with dual master cylinder for differential braking. Red-white-blue patriotic vinyl wrap. Additional pics and info available on request. Fits on 12 ft flatbed trailer or modified boat trailer, wings fit in bed of pickup. Selling for cost of parts at $25,000. Located in central NH.
