eschrom
I wonder if you guys flying Revmasters can help with this. Two guys at my airport have recently completed Onexes with R-2300s and both have had generator trouble. One has burnt one of his stator rings (a semi-ring, actually - two separate generators make one ring) and the other has blown a fuse and is now reluctant to fly with the generator operating. The problem seems to be the battery. Each is using a lightweight Li-ion battery that, as I understand it, has less internal resistance than a lead acid battery, creating high current in the generator. Revmaster doesn't seem to have a definitive answer for them. One is going to try an adjustable B&C voltage regulator but isn't sure that will work.
Li-ion batteries have been around for a while - it seems to me many others must have had this problem. Does anybody know the solution?
Thx,
Ed
Thx,
Ed
