W
WallyB
Greetings all. I've been out of the circuit for a while (literally). On a positive note, I finally have ol' 394WB certified & licensed. It may cheer some to know it is in Experimental category. No problems other than much confusion,miss mailings & spelling at FSDO. 'Nuff on that. On the down side,I haven't flown it yet due to lack of continous power. The Zenith 1821S side draft seems to be the culprit. No mixture & just one idle adjust screw on top. After several small adjustments on the idle air screw,Engine(1915)starts easily,runs fine up to say,25-2700 RPM, coaxing of the throttle will get it up to about 33-3400 RPM static. Any further forward throttle movement will then immediately make it sputter on down to 1000 RPM + or - 200. When it is at 33-3400, the slightest small application of the choke seems to keep the engine steady at 3400 RPM until reducing due tocylinder head temps getting a tad hot. Steve Bennet says the main jet must be drilled out (size?) until it maintains full power. Have any of you folks used and or drilled a Zenith carb or had similar problems with yours? My apologies for this lengthy essay, but Zenith infohas been hard to find thus far. Happy 2008 to all. Wallyb
