O
oaklandaviator
Hello everyone,
I'm a new member and just getting ready to start building a Sonerai II LS. Really getting excited about it. I've got a few questions that are probably pretty rudimentary, but here they are anyway:
Regarding engine options, has anyone put a reduction drive VW on a Sonerai (obviously would require a cowling mod) and if so how's the performance?
Would it be better to stick with a Keep It Simple approach and use a 2180 direct drive? What's a realistic cruise speed & climb rate with this setup? Orrrr, would the 2300 type 1 with aluminum cases do better?
Finally, I like the look of the AeroVee engine also. It comes with a starter, carb, and dual electronic ignition; but I don't know if that design with the starter at the 9 o'clock position (I assume from looking at the pictures) will fit on the Sonerai. And the carb they're advertising almost sounds too good to be true. Any opinions?
Thanks in advance!
Thanks in advance!
