Schmleff
Here you go. The bump in the cowl shown in the pictures was to accommodate his starter. Its and otherwise unmodified stock cowl. He has since re-engineered it and moved the starter elsewhere.
Upgrade Nowjwalin said:great pics!! so, it will fit in a stock cowl, without the starter and ring gear as in the GPASC setup. I like it....but......
that leaves me with hand propping....which is fine....I plan to do this anyway with an X casting instead of the Diehl. But I feel it is better to drive the prop off the flywheel end than the nose.....this is just my opinion, I don't want to start a debate.
and eliminating the accessory case saves weight......which opens up the possibility of a type 4 without the added weight in the nose.....
just thinking......
